Sign in to follow this
Followers 0
bmmc
ge gtwp1000m0ww no spin or agitate
5 posts in this topic
this is the old motor without the inverter.lid switch is good,suspect motor or timer but the wiring diagram in the mini manual is useless.need help pinning it down to motor or timer before giving customer an estimate.
Does the motor run?  Might be gearcase related.
motor does not run.120v from neutral to blue & red at motor plug.
  Where are you picking up your neutral? Did you try at motor connector yellow wire and wht/red wire? If you have 120vac between blue and yellow wire and no noise from motor, motor is faulty. If you only have it across blue and wht/red, motor thermal overload is bad but same conclusion, faulty motor. I don't understand the problem with the wiring diagram, this is about the most basic washer you can get.
Eric
2 people like this
while the Motor is connected ?
Does the Motor make any noise ?
Followers 0
