Asko D3251 Diverter Valve replacement
2 replies to this topic
#1 luddite20
luddite20
  • 1 posts
  • Flavorite Brew:ipa
Posted 09 June 2013 - 04:37 PM
Hi Everyone-
I am assuming that the diverter valve on my Asko d3251 is faulty.  The lower arm swings freely, is unobstructed, but water is only coming out of the top arm regardless of whether or not I isolate the bottom arm (through the buttom that controls the diverter valve.)  The metal spray tube that connects the upper and lower arm seems to be tig welded onto the back.  First question, how is this removed during the process?  I see that the spray arm likely needs to be removed from the diverter valve top before the diverter valve can be removed.
Once the spray arm is out of the way, I'm assuming the gray top to the diverter valve can be unscrewed?
Any help would be great.
Chad
#2 PDuff
PDuff
  • 2,091 posts
Posted 10 June 2013 - 01:04 PM
Have to remove dishwasher for this one.  Locking nut that holds diverter in place only accessable from underneath.  Remove lower spray arm by pulling up.
    Shōgun
  • Master Samurai Tech
  • 30,715 posts
Posted 10 June 2013 - 04:19 PM
Diverter valve:  http://www.repaircli...ber=D3251/Black
