Maytag dryer cutoff
8 replies to this topic
#1 mpm8789
mpm8789
    Ikkō-ikki
  • Chief+ Appliantologist
  • 43 posts
Posted 10 June 2013 - 06:36 AM
So the thermal cutoff was bad so I replaced it with one from the kit 279769 but silly me didnt replace the high heat thermostat because  I wasnt sure if it was the correct one and it went bad after the first load.  So my question is do you guys use the kits on these or the cutoff and thermostat specified by whirlpool.
    Shōgun
  • Master Samurai Tech
  • 30,541 posts
Posted 10 June 2013 - 08:01 AM
After my first call back on one for this very reason years ago, I ALWAYS use all components in the kit.  And now you will, too!   :dude:
Thermal cutoff kit:  http://www.repaircli...Kit/279769/2821
Thermal-Cut-Out-Fuse-Kit-279769-00699523
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 10 June 2013 - 08:18 AM
... So the thermal cutoff was bad so I replaced it ... and it went bad after the first load.
Dryer Vent 4" diameter
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
$ 3.99 sometimes on sale for $ 2.99
#4 nickfixit
nickfixit
  • 2,200 posts
  • Flavorite Brew:Glen Livit
Posted 10 June 2013 - 08:34 AM
Have you seen the whirlpool flash with instructions to swap positions of the high limit and TCO on standard top filter models? It says the TCO is supposed to be at the lower end of the heat tube, just the opposite of the way they come out of the factory.
    Shōgun
  • 30,541 posts
Posted 10 June 2013 - 08:37 AM
I have not seen that!  Will try to find that and post it here on the site.  Thanks for mentioning it!
#6 mpm8789
mpm8789
    Ikkō-ikki
  • 43 posts
Posted 10 June 2013 - 09:10 AM
I forgot to post the model Mgdb400vq0. My question is will the kit work on this model becuase the thermostat is different and the parts diagram the kit doesn't come up.
Michael
#7 RegUS_PatOff
  • 33,588 posts
Posted 10 June 2013 - 09:49 AM
How's the Belt for the Blower Assembly ?
MGDB400VQ0
parts list & tech sheets
http://appliantology...yer-mgdb400vq0/
#35    8573713 Thermal Cut−Off
http://www.repaircli...R=154&N=1180872
#36    3391912 Thermostat, High−Limit
http://www.repaircli...?R=154&N=526280
High-Limit-Thermostat-3391912--00948194.
#48    3390719 Thermal Fuse
http://www.repaircli...sp?R=154&N=2923
#8 mpm8789
mpm8789
    Ikkō-ikki
  • 43 posts
Posted 10 June 2013 - 11:34 AM
the belt to the blower and blower seemed fine.  The thermal fuse was fine as well but would you still replace it?
#9 RegUS_PatOff
  • 33,588 posts
Posted 10 June 2013 - 11:53 AM
usually just the parts that are bad ....
Normal operating temperature is determined by the Thermistor  .
AND check your Vent System
