Kenmore Ultra Wash Dishwasher Model 665.17373301 - No Power
6 replies to this topic
#1 dsarkis
dsarkis
  • 15 posts
Posted 10 June 2013 - 09:16 AM
Hello Appliance Guru,
You recently helped me replace my refrigerator fan motor, and now it runs like a champ.  Thank you.
New prolem:  Kenmore Ultra Wash Model 665.17373301
Won't turn on, no power to control panel, water in the bottom.
Would appreciate any links to trouble shooting and then repair videos once the problem is diagnosed.  I've always found the videos much more helpful than the written instuctions.  Thanks.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 10 June 2013 - 10:08 AM
Kenmore 665.17373301
tech sheets
http://appliantology...dw-66517373301/
How's the Thermal Fuse on the Control Board ?
http://www.repaircli...?R=154&N=959376
#3 dsarkis
dsarkis
  • 15 posts
Posted 10 June 2013 - 11:06 AM
Thermal fuse is blown.
#4 RegUS_PatOff
  • 33,588 posts
Posted 10 June 2013 - 11:51 AM
when replacing, need to read the instructions and use the included wires
#5 dsarkis
dsarkis
  • 15 posts
Posted 10 June 2013 - 12:27 PM
The video mentions the fuse could be a result of a bad thermometer or heating element.  How do I check so I don't blow my new fuse?
#6 RegUS_PatOff
  • 33,588 posts
Posted 10 June 2013 - 12:44 PM
your model had a problem with blowing the Fuse, that's why the included the extra wires to move the Fuse from the surrounding heat of the Controller Board.
OR
the heat generated by the (bad / wet) connections
#7 dsarkis
dsarkis
  • 15 posts
Posted 10 June 2013 - 12:58 PM
OK thanks.  Will order the fuse, install as directed, and let you know if it goes again.
