Learn how to be your own tech line…
Sign in to follow this
Followers 0
bigjtham
Whirlpool LSR6334LQ1 washer problems
3 posts in this topic
washer will start in wash cycle then after a few minutes it stops and will not restart  doesn't seem  to mater in what setting wont spin or drain  Was looking for the service manual but couldn't locate one . Any ideas or a manual would be welcomed , Thanks
  After it stops, does the timer continue to advance on it's own? Try spin mode as well. If timer doesn't advance in either agitate or spin, check connection at motor. Could be loose connection, burnt/corroded contacts or the motor thermal overload may be tripping. Check for continuity between white and white/black wire at motor when washer quits (unplug washer before checking).
Eric
Followers 0
