Whirlpol cabrio WTW6600SB2
F32 error
35 replies to this topic
#21 Spannerwrench
Spannerwrench
    Mutsuhito
  • 1,127 posts
Posted 28 July 2013 - 07:12 AM
I have seen bad connections on the drain pump connector before causing similar problems.
"Suds are not good"
"Occam's Razor 'the simplest answer is most often correct'"
#22 certified tech group 51
  • 2,712 posts
Posted 28 July 2013 - 10:05 AM
And now for something completely different..................How far down in the stand pipe is the drain hose????.................Is the drain hose held in place by something like  electrical tape????........How many control boards have you replaced???????
#23 fixit guy
fixit guy
    Sōhei
  • Scholar of Appliantology
  • 128 posts
Posted 28 July 2013 - 05:44 PM
I have seen this many times and there are several problems that can cause this,
   debris in drain hose.
   Pump.
   connections at pump or board. Wiggles wires at pump they might come right off.
   Debris under coin trap,  did you remove it?
Hope this helps!
Fixit Guy
#24 lesguns
lesguns
  • Chief Appliantologist
  • 19 posts
Posted 28 July 2013 - 08:52 PM
I would try hall sensor then board.
#25 Patricio
Patricio
    Opa
  • 1,614 posts
  • Flavorite Brew:Home brewed ice tea
Posted 28 July 2013 - 11:07 PM
Different is the spice of life
Checked drain hose placement even held it out of the drain pipe while it drains.   Something I always check on every washer repair.  Held in place by standard hose keeper that is prevalent on 90% of machines I see.
Replaced a few, more than I would like on these machines for the F1 code.   I did not replace the board on this machine, authorized whirlpool factory tech replaced this board last May.    Can you clue me in on how to test other than power in & power out?   Have not had a continuing problem like this  one.   Replaced many pumps, bearings, and other mechanical devices on all kinds of machines from mowers, tractors, vehicles etc.  I am an old farm boy that has repaired more things than I can remember without proper tools.
What are you leading to on control boards, something I may not Know...clue me in...bottom line...I am going to figure it out.   Rather sooner than later.
   Pump.
Hope this helps!
Fixit Guy
Sure it helps.   Checked drain line as it was pumping water out, flow seemed full.   Did blow line from drain pipe side to pump side when replacing pump, try to cover all my bases.   Wiggled wires, I do that on every thing, old habit from my young days.   Before I installed pump I pulled basket, cleaned gookus from hub, & yes I scrubbed cointrap & everything else.   I try to be thorough on everything helps prevent call backs.
Edited by Patricio, 28 July 2013 - 11:08 PM.
Former Student of Master Samurai Tech School.   Current Student of  Master Samurai Tech School
http://www.mastersam...iliate.php?id=5
#26 Patricio
Patricio
    Opa
  • 1,614 posts
Posted 28 July 2013 - 11:13 PM
I was thinking hall sensor & water level tube.   I have that in backstock.      Thanks for the replies every one.   Can any one post up any other perks that they have come across.   I have read a lot of negativity from a lot of techs on this machines.    I look at as just another machine that breakes down & needs repairs,
#27 nickfixit
nickfixit
  • 2,200 posts
  • Flavorite Brew:Glen Livit
Posted 29 July 2013 - 05:40 AM
I've been down this road, only got relief with a new board. I have had new controls NFG out of the box. I've also had a plugged recirc pump take out the drain function, no idea why.
#28 fixit guy
fixit guy
    Sōhei
  • 128 posts
Posted 29 July 2013 - 06:28 AM
Try this, put the machine in diagnostics, turn on drain pump.  Wiggle wires at P-4 on control while pump is running.  Then wiggle wires at pump while it is running.  This is how I found problem on intermit drain several times.  Good luck!
#29 Patricio
Patricio
    Opa
  • 1,614 posts
Posted 29 July 2013 - 09:01 AM
Good to hear I'm not the only one with a temperamental cabrio.     All good tips from actual experiences.  Keep them coming  I like it.
#30 Patricio
Patricio
    Opa
  • 1,614 posts
Posted 30 July 2013 - 10:58 PM
Todays education:  Put a big load in it after I moved into the garage & back out on the porch (dog likes to jump up on things in his turf)   Went into drain mode for the rinse cycle & just drained & drained,  I wiggled wires all over the place, no hiccups, just LD code.   Would not go into any other mode but drain, pump works great.
Realized that maybe moving machine with a truck dolly might of wacked out water level sensor.  Put machine into manual diagnose then calibration & started a quick wash.  Went thru cycle until the load became out of balance. I let it fill & readjust itself, did this several times.  Finally I had to pause it & manually adjust the load to balance, took a few times.  It finally began to run again & did not go to the LD default.  Spun out the last 11 minutes like it is suppose to do reaching its maximum high speed the last few minutes of cycle.
Interest tidbit. Every time I paused the cycle during the unbalance lid would unlatch but lid lock light would stay lit.   Any takes on this.   I will study the machine again tomorrow when I have the spare time.
#31 sh2sh2
sh2sh2
    Senpai
  • PipPipPipPip
  • 848 posts
  • Flavorite Brew:yeunling
Posted 31 July 2013 - 06:53 PM
next time it get stuck where it just drains and drains, unhook the pressure hose from the controller, this would rule out clogs, kinks, suds and the such.
#32 MicaBay
MicaBay
    Master Roaster
  • 1,085 posts
  • Flavorite Brew:Drifter Pale Ale
Posted 01 August 2013 - 09:10 AM
Patricio, how goes this battle?
#33 Patricio
Patricio
    Opa
  • 1,614 posts
Posted 01 August 2013 - 03:39 PM
Already have done this, just pump & pumped.   No time for it today, plan tomorrow evening.   Will keep updated.   Patricio
#34 sh2sh2
sh2sh2
    Senpai
  • PipPipPipPip
  • 848 posts
Posted 01 August 2013 - 07:34 PM
i would highly suspect a bad board
#35 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 31,150 posts
Posted 01 August 2013 - 08:30 PM
Main control board:  http://www.repaircli...mber=WTW6600SB2
Main-Control-Board-W10189966-00704579.jp
#36 Patricio
Patricio
    Opa
  • 1,614 posts
Posted 01 August 2013 - 10:02 PM
That is where the rub is.    I suggested the board is bad, customer calls Whirlpool, they say they back their boards with a 90 day warrantee.  They installed it free of charge because of a F1 problem less than 90 days before I suggested it is bad.    They send A&E out who claims the long drain is because of a bad bearing, I install new set & here we are again, suggesting bad board.     Catch 22.   Will give it more time tomorrow evening.
