scooterb13
Samsung RB215LASH defrost issue
11 posts in this topic
I am working on a Samsung RB215LASH refrig. that had frosting issues in freezer section. Traced out problem to an open thermal fuse, replaced fuse and then the defrost heater would stay on even when compressor is running. Replaced main board but still have 120v. to heater when compressor is running. Checked for grounded heater, but it's ok. Does anybody have any ideas?
Where are you measuring that voltage?  CN70, 13-7 on the main PCB?
I checked the voltage at the heater harness plug in the freezer w/ the heater unplugged (brown to red wire at thermal fuse). I didn't check directly at the board terminals.
... w/ the heater unplugged
all voltage measurements should be made with the devices connected
unless otherwise directed
120v. with the heater connected or not connected, the heater on when it is connected, even when the compressor is running.
That's what I thought, so I replaced the main board & no difference. Very strange one. I just got a call from the customer and they decided to get a new (non Samsung) refrig. so I told them I would take Samsung and bring it to the shop and get to the bottom of this.
... so I replaced the main board & no difference.
new ?
Brand new exact Samsung part.
If the Compressor and Defrost are on at the same time,
it would seem to be a bad Controller Board
That's what it seems it would be, maybe I got a defective new board. I will be checking it again tomorrow at the pins on the board and post what I find. Thanks
