  • Announcements
AlexM
Maytag Gas Range - Model# JGS9900BDS; Control Board (or) Touch Pad Assembly?
6 posts in this topic
I'm not sure which part to order, or how to test for what part is faulty.
The burners work fine, the touch panel lights up, but I can't get the oven to turn on, when I press the oven/bake buttons nothing shows on the screen and there is no functioning.
I figure its either the main control board P/N 74011872 or the panel with the touch pad P/N 74011866 ? is this right?
I wouldn't mind running some test on this range vs just ordering expensive parts. If anyone has some test recomendations, I would much appriciate.
Thanks
Unresponsive trouchpanel is usually caused by a bad keypad in the touchpanel.  Tech sheet behind the bottom panel has the ribbon connector pinout for the touchpanel.  Actuate/ohm-test each key pad on the touchpanel.  You'll probably find one of them stuck closed.  This makes the ERC lockout the touchpanel.
Touchpanel:  http://www.repairclinic.com/PartDetail/Touchpad-and-Control-Panel/W10206071/1472791
Thanks for the info, and tech information.
Is ohm testing touch pads and looking for a closed button a universally accepted way to test touch pads?  If so, my life could have just been made easier?
Thanks,
... Is ohm testing touch pads and looking for a closed button a universally accepted way to test touch pads?
yes
I think Maytag ( Whirlpool ) owns the smelter where those aluminum panels are manufactured.................Do some key pads function and others not ????
