Troubleshoot modern appliances with confidence…
kathyplumb
Pinhole in Frigidaire outer tub
6 posts in this topic
Hi!
A drywall screw caused a tiny pinhole leak in the bottom of my upright Frigidaire outer tub.  I called JB Weld and they did not recommend any of their products because they feared the tub was made of polyethlyene.  3M told me the same thing.  I can't tell fiberglass from polyethylene.
I stumbled upon Slap Stix but unfortunately the pinhole is right next to a protruding tab so there isn't a flat space all the way around it, so I assume that wouldn't work.
I'm hoping to find a product to repair the hole from the outside without having to remove the inner tub  to get to the inside.
Any suggestions for proven remedies?  I'm a chick, but I'm handy!
P.S.  The plastic ID symbol on bottom of the tub is a 7.  It says, "PP-T22" underneath.  I guess that stands for polypropylene...
There's a product I use to tape around the AC air handler access panel.  It is 2" wide and comes in a 25 foot roll. NOT the plain, thin sticky foil tape. This stuff is about 1/8 inch thick.  I don't know the exact name for it, but any AC parts house should carry it. Not sure if HD or Lowes has it.
It has a silver backing and an extremely strong adhesive sealer on it (probably water proof for a pinhole size leak).  Very flexible and you can cut to fit. Just make sure surface is clean and dry before applying the tape.
Hope this helps.
I would use epoxy. Clean the area, rough it up with some sand paper, clean it again, then make your epoxy patch. You could even remove the basket, and patch it from the inside too. I've used JB weld and Loctite brand epoxies with no issues.
Thanks much. Good to know
Looky here.  Says it structurally bonds polypropylene!    1 oz $14.95
TAP Poly-Weld Adhesive
TAP Poly-Weld Adhesive: Imagine being able to structurally bond Polyethylene!!! This has been virtually impossible in the past. Now, with a simple flame treatment and Poly-Weld, one can create strong joints on Low, Medium, or High Density Polyethylene. Use for tank, door, pipe, irrigation, pond, marine, float, & automotive body repairs. Also bonds polypropylene, ABS, PVC, ceramics, rubber, fiberglass, metals, and glass. Exterior-rated. Non-sag formula.
http://www.tapplastics.com/product/repair_products/adhesives_glues_sealants/tap_poly_weld_adhesive/435
