Cycliste
Maytag 2000 Series Washer overflows from drawer
4 posts in this topic
Maytag 2000 Series Washer, model MHWE200XW00 ser HL02020857. ~2 years old.
It started with a low fill error code (LF). I checked the inlet valves, cleaned them (there was a lot of sediment on the cold side). Plugged back and reconnected  the washer, then it overfilled right from the drawer after ten seconds, like if water was not getting into the drum. I drained the machine, tried again but with the same result.
Thank you in advance.
Pierre
Long Island, ME
suspect an item stuck in the dispenser funnel where it spills into to the tub...all it can be, really..
1 person likes this
Bingo! There was a pink underwear stuck in the hose between the drawer and the drum. Most difficult was to put back the hose and panels back together.
Machine running fine now.
Thanks Kurtius! :)
1 person likes this
