Need Whirlpool/Kenmore wiring diagram 8539980
fairbank56
Need a model number so I can add it to the Downloads section.
My eyesight isn't as good as it once was blink.gif (see RegUS_PatOff )
but from here, it looks like your model number may be
110.24932200
enter tech sheet number into ServiceMatters
The list of model numbers appear..
this only had one model listed
24932200
must be Kenmore..
add 110.
Verify at Sears..
Usually multiple models listed,
including the real Whirlpool's
