bedwards0978
Admiral fridge LSD2615HEW Defrost Problems
8 posts in this topic
I went out to this fridge with a no cool issue back in January and diagnosed a bad ADC board. I replaced board and all was good. I got a call 5 months later that the fridge was having a no cool issue again. I manually put the unit in defrost and everything was working, bad control board again. I replaced the board under warranty and went on. I get a call today that the fridge is not cooling again. I have not went out yet, but I can only assume that the heating system is going to work when manual defrost is initiated. Is there something that I am missing on this unit. The calrod element is working, is it possible that it works but does not work good enough??
Just for FYI, my suppliers look up system shows part#12002495 for the ADC board. When I put the model# into RepairClinic it shows part#67004704. I am a little concerned about the discrepancy there.
Thanks ahead of time.
Another question. What could explain the long periods of time that it takes for the evap to ice up to block air flow?
may need to see a picture of the Freezer Evaporator frost pattern
67004704
seems to be for a different model number ASD2324
LSD2615HEW
original ADC part number
67003375
The manufacturer has replaced part number 67003375
with this item, part number 12002495
http://www.repairclinic.com/referral.asp?R=154&N=1184282
Defrost-Control-Board-12002495-01025462.
1 person likes this
Don't have a picture, but both times I have been out the evap has been evenly coated over the entire body
if it's the board going bad again, definitely have customer put a surge protector on it. btw is it connected directly to a standard outlet?
Yes, last time I was there I measured 119v and it was not a GFC circuit.
I'm looking at the other components wired with the adc that might be eating these boards.  Defrost bi-metal on the verge of shorting out.  Freezer temp control sticking.  Excessive compressor run time.  On your return trips, are you finding heavy frost or icing on the evaporator before engaging defrost?  Icing would indicate a deeper problem, possibly sealed system related.  Heavy frost might lean toward a control issue.  Might consider a new freezer cold control along with the new adc.
2 people like this
Definitely is very thick and frosty. There was no ice to my recollection, just frost build up. May give the cold control a try. May explain why it is taking so long to completely frost over.
btw What are the fridge and freezer temp setings?
