jmiller202045
Don't know what this part is called
4 posts in this topic
I've got an Admiral dryer, model LNC7761A77, about 12 yrs old. Just stopped running during a load. I've located the faulty part, but I don't know what its called so I can locate a new one. I think its the thermal fuse cutout. My heating element compartment is located high on the back wall and the part I removed and ohmed out, is about 2 inches down from the top on the right-hand side of the element compartment. I ohmed it out and got no continuity. When I taped the two wires together temporarily and bumped the timer switch, the dryer came on. This part is round and about the size of a dime, with no markings. Thanks.
that would be the Hi-Limit Thermal Fuse,
comes as a kit,
Includes (yellow dot) for Gas Dryer, (pink dot) for Electric Dryer..
also includes Hi-Limit Thermostat,
which also needs to be changed.
http://www.repairclinic.com/referral.asp?R=154&N=3344
Thermal-Cut-Out-Fuse-Kit-LA-1053-0092869
usually caused by a clogged Vent System
Check / clean the Dryer Vent
Dryer Vent 4" diameter
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
$ 3.99 sometimes on sale for $ 2.99
Thanks for the help my friend. Greatly appreciated. Not to open the forum to everything under the sun, but I'm a 31 yr. journeyman electrician. If I can ever help you with an issue, my email is jmiller202045@yahoo.com.
Restricted exhaust ducts tend to blow this fuse.
Check your ductwork.
