Skiter29
Whirlpool Duet with f25 code
2 posts in this topic
got a whrilpool duet model #wfw9200sq0 it is getting a f25 code around the 25 min mark if i put it in dionostics it will run through the diognostics fine it will show a stored f25 at the beginning and if you run it through a cycle with it empty it will run fine if you put in on drain and spin empty it run fine but with clothes in it it stops if the clothes in it spin and drain wont run ohm out the tac and motor they check out called whrilpool tech line and said machine was ok but it is not any ideals out there
I've seen the error caused by badly worn drum bearings.  Give the inner basket the shake test:
