rocknronnc
Bosch dishwasher making draining noises
6 posts in this topic
my Bosch dishwasher SHX46A is usually pretty quiet, i just recently had to replace the drain hose because of a leak and now when it is going through its cycles i am noticing draining sounds where it empties into the garbage disposal. i did not notice these sounds before,  i connected it up just as it was with the old drain hose.
I'm guessing your old drain hose was leaking from where it was kinked, possibly during installation.  With your new drain hose properly installed and free of any kinks or restrictions, the dishwasher is now draining the way it was designed.
1 person likes this
You hear the sounds,but,do you see the water draining?
yes, i see the water draining into the garbage disposal.
Another words, before it had a partial restriction slowing down the water therefor you never heard the water splash into the disposal. This is normal now that the hose has no restrictions. I'd be worried if I didn't here it.
I misread your post.
I thought you were draining while washing.
If it is only doing this while draining,all is good.
