lrning
Oven and preheat green LED on then Off Frigidaire model FEF365BGWE
4 posts in this topic
I have glass top stove and oven
  model FEF365BGWE
  Serial n F11611085
  the top surface works good.
 the oven bake,I press and set at 350 degree, it just flash the green oven LED On and the pre heat green LED On,  after that
   the temperature 350 degree switch back to the clock status.
 no heat and or notthing warm in the oven.
where should I look.
 i opened the back panel,  all wires are in good condition, opened the printed circuit board area , all wires look ok, no burnt smell or smoke
thank for any help
Check for proper voltage at the control. If voltage is correct I'd replace the control.
