Fixing a warm Amana bottom-mount refrigerator, Pt. 5: Reassembling the freezer compartment
Amana Jenn-Air Maytag bottom-mount refrigerator freezer disassembly
1 reply to this topic
#1 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 30,182 posts
Posted 18 June 2013 - 03:25 PM
This is Act 5 and the grand finale of the runaway Broadway hit five-part appliance repair rock opera, "My Darling, Amana, only gives me Warm Beer and Sour Milk."  The complete playlist is here:  http://www.youtube.c...sSaRLcc7UhMELje
Be dazzled as Samurai Appliance Repair Man effortlessly leads you through the re-assembly of the freezer compartment in an Amana bottom-mount refrigerator. BONUS: by reversing procedure the Samurai illustrates here, you can also disassemble the freezer! It's like two videos in one!
Here are links to some of the freezer door parts used in these bottom-mount Amana's.  These are brand new, genuine OEM parts that come with a one-year return policy:
Freezer door glide and gear kit:  http://www.repaircli...873?RCAID=24038
Freezer drawer slide rail: http://www.repaircli...333?RCAID=24038
#2 DurhamAppliance
    Sho' Nuff Chozin
  • 5,457 posts
Posted 22 June 2013 - 02:35 AM
Once you have mastered the proper technique as shown by the Samurai, you can try a few advanced time saving moves.
You can remove the evap panel without taking the bottom rail guides.out... or take out just one. During reinstall, put the bottom of the panel in first, making sure it is outside of the drain pan. Btw don't forget to pull the thermistor through the panel before you set the top part of the panel in place. It ia very easy to forget.
You can also try removing the freezer door and sliding rails together thus avoiding the frustration of having to set the door onto the rails during reinstall. Use a long screw driver (I find that a really long screw driver.. uh uh.. longer.. is indispensable during several stages when working on this freezer drawer from hell) to press a rail tab in, pull the door on that side sllghtly to slide that rail out just enough to cover the tab and keep it from relocking. Do the other side, then slide the door and rails out as one piece.
To reinstall, simply align the rails (balance the door on your foot if you must) then close the door. Easy peasy! But what is that little piece of plastic you placed inside the basket? Uh huh, no need to hide it.. thermistor cover right? .. forgot to pull the thermistor through the evap panel again didn't ya? Look on the bright side.. you get to practice removing and reinstalling the door and rails again. I aint laughing, only chucking for how do you think I became so good at it?
www.DurhamApplianceThrift.com
Also tagged with one or more of these keywords: Amana, Jenn-Air, Maytag, bottom-mount, refrigerator, freezer, disassembly
