acfixerdude
Sub Zero 550 compressor replacements?
6 posts in this topic
Looking for a cheap replacement compressor (for both the refer and freezer) for a Sub Zero 550 w/ R12.
Planning on using an R409 drop in and using comparable compressors that will fit. Any suggestions on what compressors will work?
Sub Zero part numbers:
Freezer compressor - 7014067
Refrigerator compressor - 4201670
Need to get these replacements ordered today, please help!
Thanks!
I pull the compressors... Flush the lines with rx11 flush kit.... Purge them with nitrogen... Install a r134a compressor... Pressure test the lines with nitrogen..,. Vacuum.... Add r134a. Oh yea and put new drier filters in.... Ill find the pn one second
Ff8.5hbk. This is a great compressor that uses low preasure so it last forever. Into sure if it works with r409 but its rated for both f134, r12, r134a.
If it's rated for 134 and 12 then it doesn't come will oil in it. The oil used in 134 is not compatible with 12.
According to Johnstones,
For low, medium and high temperature applications Charged with POE/ISO22 oil Direct replacement of OEM compressors in commercial refrigeration BtuH capacity ratings are based on the following low temperature conditions: 130°F condensing, 90°F return gas, 90°F ambient and 90°F liquid temperature at the expansion valve
looks like its made for 134a
Could I use this same part for both the refer and the freezer?
Also, if I were to go with R134a how much would I put in; whatever the data tag says or is there a conversion?
http://youtu.be/O9LpJ9QyZM8. I put in until about 3lbs stable on psig..... That's a vid oh how I do it. I don't claim to be an expert but I have done a ton of these.
Some compressor for both. This might not be the most efficient compressor but it had a long life.
Also if u have never flushed a line set wear eye goggles it may spray back at you. Be careful.
That's correct r134a. Was driving and trying to type.
