Learn how to be your own tech line...
Sign in to follow this
Followers 0
AcklandAppliance72
Frigidaire Affinity Front Load Washer E68 Error Code
6 posts in this topic
I just looked at an Affinity front load washer that stops running a few seconds after the door latch light goes on.  I pulled up the error code, and got E68: "Current leakage to ground on heater or fuse opened".  I tested the heating element for resistance between the terminals, and to ground, and it tested out okay.  Is there actually some fuse in the machine that could be replaced, maybe on one of the boards, or do I most likely need to replace the main control board?
What was the resistance of the element?  Should be about 14 ohms.  Depending on your model there may be a heater control board.
The resistance of the element was 15 ohms.  Yes, there is a heater control board. Is there a way to test that board?  I have the Frigidaire service manual which describes how to remove the heater control board, but doesn't give any specs for testing it.
To my knowledge there are no tests for the heater control board itself. Make sure that the heater is not shorted to ground. I believe you also may be able to try disconnecting the heater and see if the problem goes away, I may be wrong. But there is no direct wiring from the main control to the heater, only from the main control to and from the heater control. So the heater control would be the part telling the main control there is a problem with the heater. If you're sure the heater is not faulty you would need to replace the heater board I would suspect.
Check the wire connections from the heater to the heater control at the J2 connector C3-1 and C3-3.  Might be a short in the wiring.
Thanks for your words of wisdom, PDuff and Spannerwrench.  I went back to the customer's house and checked all of the wiring connections.  I discovered that the heater control board had broken loose from the cabinet and was flopping around during a fast spin.  One of the wire connections was so loose that it fell off when I touched it.  I secured it with strapping tape because this woman needed her washer up and running pronto.  (I can replace the broken mounting bracket later.) I did replace her heating element as well, because it had some suspicious corrosion and the PTC thermistor resistance reading was way off.  The unit is working great.  She was so happy that she sent me off with a loaf of banana nut bread (as well as a check for parts and labor-senior discount applied).
Followers 0
