Bosch SHX33A starts to fill but will not run
5 replies to this topic
#1 dave42
dave42
    Sōhei
  • 149 posts
Posted 21 June 2013 - 10:16 AM
We have a Bosch SHX33A dishwasher that one of our renters put soap in rinseaid. I removed unit and flushed it well and filled with rinseaid. That was last month. Just came back today after a month and now it sounds like dishwasher starts to fill and making intermittent filling and draining sounds for about 10 sec. Then I just hear an occasional hum. No washing at all. Is something clogged? Thanks.
Dave
#2 Spannerwrench
Spannerwrench
    Mutsuhito
  • 1,145 posts
Posted 21 June 2013 - 10:29 AM
Seized motor, the unit should drain for 30 seconds, fill with water, then turn on the wash motor. If it's doing the first two and then just hums, the motor may be seized. I can't remember what size nut driver to use, but if you remove the filters insert in the slot to the right and you should be able to turn the motor manually. Then try again. It may work but you should install the repair kit.
Part number: AP2802376
"Suds are not good"
"Occam's Razor 'the simplest answer is most often correct'"
#3 dave42
dave42
    Sōhei
  • 149 posts
Posted 21 June 2013 - 10:54 AM
Is it a torx screw? You mean the horizontal hole on the right?
#4 Spannerwrench
Spannerwrench
    Mutsuhito
  • 1,145 posts
Posted 21 June 2013 - 11:26 AM
Looking into your unit it is to the right,, correct a horizontal slot. It's more like a 5/16", 3/8" or 7/16". But looking at this image it would be where the Blue arrow points to the right towards the impeller. I usually don't free them up anymore, I just use the impeller pump repair kit. If you free it up, you most likely are damaging the seals at the same time. The kit comes with replacement seals.
"Suds are not good"
#5 dave42
dave42
    Sōhei
  • 149 posts
Posted 21 June 2013 - 11:49 AM
I am just going to replace dw. Was never a huge fan. Just want to be sure though. Water definitely goes in. Then I get this intermittent hum every 10 sec or so. When I did hit cancel drain, I hear some sloshing now but water not really leaving. There is some in white cup at bottom. I turned blue impeller on left (for drain) and it does turn.
#6 dave42
dave42
    Sōhei
  • 149 posts
Posted 21 June 2013 - 11:54 AM
Actually, put cover back over drain impeller and water exits. But as with original problem, water enters then I hear intermittent hum. So motor is shot? I can see that black grey metal of motor is rusted.
