Kentucky-Fried Bake Element in an Electric Oven: Analysis and Replacement
oven bake element fire spark range electric arcing
1 reply to this topic
#1 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 29,810 posts
Posted 23 June 2013 - 07:50 AM
In this action-packed episode of Appliantology TV, Samurai Appliance Repair Man tip-toes you through the tulips of replacing a Kentucky-Fried bake element in an electric oven.  A Kentucky Fried element is one that has gone FWF  (Failed With Fireworks, arcing and sparking).  Whenever you're dealing with a Kentucky-Fried element, you have to check to see if the control board has been damaged and that's exactly what the Samurai shows you how to do.
Here's the replacement bake element I used to fix this oven:  http://www.repaircli.../WB44X5082/3358
There's also another video at the link above that gives more details on the steps for replacing the element.
#2 DurhamAppliance
    Sho' Nuff Chozin
  • 5,083 posts
Posted 23 June 2013 - 12:36 PM
From his prolific appliantological mind and straight out of his amazing bag of tricks, here is Sensei Certified Tech Group 51 showing what I've found to be an indispensable tool for element replacement.... take it away Sensei.. :
I use these to grab and hang onto the wire terminals so that they do not pull back into the mounting holes...
www.DurhamApplianceThrift.com
Also tagged with one or more of these keywords: oven, bake, element, fire, spark, range, electric, arcing
