  • Announcements
Wjj
FrigidAire dryer won't start
4 posts in this topic
Fse747ges1 model
Quit workin mid cycle, everything up to that point normal. Now it won't start
Gallery heavy duty large capacity dryer
Frigidaire FSE747GE reversing Dryer c.1997 :woot:
check the thermal devices
# 36 (upper right corner)
and
# 33 (lower right corner)
Tried replacing both of the parts and neither worked. Any other suggestions.
Verify 220 volts to the dryer.
Check the door switch for continuity.
Inspect the wiring harness for a broken wire.
