Maytag Range Issue
5 replies to this topic
#1 Strathy
Strathy
    Head Wrench
  • PipPipPipPip
  • 765 posts
  • Flavorite Brew:Coffee
Posted 24 June 2013 - 09:25 AM
Model: MER5870BCW
Serial: 16177384AT
Neither bake nor broil is heating.  Found that I have 120 v on the side that comes from the board, but 0 v from the relay side.  Here is my problem:  There only seems to be 18 v coming out of the board to the relay.  Is this normal?  Further, when I check for continuity between the two black wires on the relay, I have an open connection.  My thinking is that this should be a coil and should have resistance.  See attached wiring diagram.  Do I need a relay or a board or both?
Neighbour's Appliance Service
Servicing Southern Manitoba, Canada
#2 Spannerwrench
Spannerwrench
    Mutsuhito
  • 1,145 posts
Posted 24 June 2013 - 10:39 AM
You have 120v at the relay (line voltage), 18v at the relay from the board telling the relay turn close and supply the voltage to the element. Sounds like a bad relay to me provided that the relay coil is 18v.
"Suds are not good"
"Occam's Razor 'the simplest answer is most often correct'"
#3 DurhamAppliance
    Sho' Nuff Chozin
  • 6,052 posts
Posted 24 June 2013 - 10:45 AM
took me a bit to analyze this as I am in the midst of training myself on the wonderful world of electronics and schematics.... so thanks Strathy for the excercise. Amazingly, I came to the same conclusion as Spannerwrench. I don't know if that's a good thing or not. lol
My question to the masters is whether a board diagram would show the proper voltage output at the board's relay connector, or voltage listed on a block diagram of the relay or do you have to read the relay itself to see what voltage is required to energize the relay coil?
www.DurhamApplianceThrift.com
#4 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 24 June 2013 - 11:28 AM
part number on the Relay
T9AP5052-24
shows it to be a 24v DC coil
maybe about 600 OHMs
Manufacturer Number 74003482
http://www.repaircli...?R=154&N=703562
#5 DurhamAppliance
    Sho' Nuff Chozin
  • 6,052 posts
Posted 24 June 2013 - 12:09 PM
Sensei Reg, the unchanging god of all things electrical and service manual-ly(?) is in total agreement with young Master Reg regarding this relay.. let us go back in time and witness.... http://applianceguru...rum1/18414.html
#6 PDuff
PDuff
  • 2,158 posts
Posted 24 June 2013 - 02:08 PM
Having the exact same problem with an LG range that has the bake/broil relay and double line break relay on the same board.  Ordered the relay board and I'll let you know how it goes.  Had a Kitchenaid double oven once that kept blowing the main control.  Turned out the DLB relay was shorted and supplying 240 volts to the main control.
