dave42
Whirlpool lxr9245e2q washer makes rattling sound at end of wash cycle before spin
15 posts in this topic
Our 13 year old Whirpool lxr9245e2q washer still runs great, but I've noticed that at the end of the wash cycle but before it spins, it makes a kind of rattling sound like someone rattling a chain. This is when drain pump seems to be emptying the water. Pump works fine and empties washer and tub then spins. I'm wondering if there is a clutch that is not engaging for a few seconds or something with pump?
I don't hear it at end of rinse cycle before final spin.
Dave
post YouTube video,
then post link here
noisy trans while its in neutral drain?  probably run like that forever
I'll have to record it and post next time we run it. Did do the test where I put it in spin mode then put my hand against inside of tub and bypassed lid switch. With a med amt of force, I could stop tub from spinning. Sounds like clutch is going, I guess.
So I followed the diagnosis of a no-spin situation, even though ours does spin. Removed outer shell of washer and jumper end lid switch. Clutch spins. I see no oil sprayed around inside of washer. If tub is spinning and I put my hand in and try to stop, I cannot. But if I start spin cycle with my hand against tub, I can pretty easily prevent it from spinning. Agitator seems to move ok.
I do hear a thud just for a split second when tub does start to spin. So it sounds like a new clutch definitely?
I will post video/audio tomorrow. Thanks. Dave
The
The thud you hear a split second before it actually starts to spin is the neutral drain latch releasing and spin pawl engaging spin gear,  this is a normal sound.
Normal behavior, not a problem.  The clutch is intended to slip while the basket gets up to full speed.  The motor would be under a tremendous load and likely stall-out if the clutch if the clutch grabbed 100%.
So everything is good then? I do not need to replace clutch per post above? We ran machine 2 or 3 times today and no rattling sound.
Remove the pump and inspect for debris.  Also check drain hose for any small foreign object that might have not been evacuated with the drain water.
You guys are great. With 3-4 complete wash cycles yesterday, i heard nothing out of the ordinary. When i have heard the noise, it sounds like something rattling around loose. Like if someone were dragging a chain repeatedly over a metal surface. Would only occur toward end if neutral drain when most of water out of washer.
I will pull pump and look for debris. Are the aftermarket (Supco) pumps or similar reliable? I can get one on Amazon for less than $10. Thanks Dave
Buying generic knockoff parts is false economy.  Seemingly save a few shekels only to find that it doesn't work right (or at all) or fails soon after installation.  My experience with buying parts from Amazon:  http://ymlp.com/zsTPYA
The OEM pump comes with a one year, no-hassle return policy:  http://www.repairclinic.com/PartDetail/Drain-Pump/3363394/3296
Will do. This washer is in a condo that we rent out in the spring months. I don't mind having it die when we are there (maybe once every 6 weeks). Then i would just replace parts. But if our renters are there, it would require a service call etc.
as i had said, there was no further noise on draining. I will check pump and hoses when we return.
Or would it make sense to just replace pump? If so, should i also just replace motor coupler since it is in same general area?
Only issue we seemed to have was the rattling sound which is gone for the time being.
While you are replacing the pump, go ahead and replace the drive coupler as well........................Will not hurt the machine and give you a piece of mind.............Just tip it back and pull the pump, drop the motor,  replace the coupler, check fore anything  oily /greasy  near the clutch.......reassemble............Use O.E.M. parts only, , you do not want to be paying a service tech. to come out and fix your mistake while you have renters  trying to enjoy them selves.................... ( I would go as for as to replace the lid switch also, our D.D. machine is 12 years old........... .Only replaced parts so far is that it is on it's third lid switch, go figure )............
Good advice!
Drive coupler part link:  http://www.repairclinic.com/PartDetail/Motor-Coupling/285753A/1195967
How-to video at the link above.
Thanks Guys. Will order all parts and replace.
