Nicky
36" viking range spark module quit again
3 posts in this topic
Just found out that A spark module quit that was only in for about 5 months. The original was in for about 7 years and this one has failed now with the same two right burners again. The left burners are fine. I already tested it and it is definitely the module that failed. I was hoping it was a common wire from that side, but it is not. Is this just bad luck, coincidence, or definitely faulty replacement? I believe part number is PA020048.   thanks
Could be all of the above.  Just check ignitor wires for short to chassis and check electrical outlet for correct polarity.  Double check affected burner spark switches as well.  If everything else looks good probably a bad module.
Oven model number ?
any part ordered from RepairClinic can be returned for a refund (less shipping)
for 365 days
including installed electrical parts
