Samsung RS2555SL
3 replies to this topic
#1 WalterG7712
WalterG7712
    Yamabushi
  • 74 posts
  • Flavorite Brew:PNG coffee
Posted 25 June 2013 - 03:10 PM
I am working on a Samsung RS2555SL. Appears to have a defrost problem on the refrig side, but after reading some of the other posts I'm not sure. Could you send me the manual or any related information?. Drain was ok, heater tested bad on 2k setting. Does the heater come separate from the evap. coils?
#2 Spannerwrench
Spannerwrench
    Mutsuhito
  • Master Appliantologist
  • 1,048 posts
Posted 25 June 2013 - 03:27 PM
Last time I had to do one I had to replace the entire evaporator, that's been a couple of years though there's also a note in the Fast Track about relocating the defrost sensor to provide a longer defrost.
Fast Track
http://appliantology...-bundle-5-of-5/
"Suds are not good"
"Occam's RAZOR 'the simplest answer is most often correct'"
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 25 June 2013 - 07:20 PM
Gotta love Samsing, to get the defrost heater replaced you have to order and replace the whole evaperator coil
which is part of the sealed system, which is a major repair
..so you DO NOT want to find an open defrost heater....
Yes (and no)
(many) months ago I read:
... I found a way to replace the broken one...
... It's not fastened by screws...
... rivets which you'll have to grind the head off.
... When you put it back together you could put more rivets in or sheet metal screws.
... pictures that show the separated defrost heater and evaporator...
... The old one was burned out at the joint.
Maytag or Samsung part number DA96-00021N @ RepairClinic
(your required part number may be different)
Special Order. Usually ships in 12-14 business days..
http://www.repaircli...R=154&N=1615796
#4 WalterG7712
WalterG7712
    Yamabushi
  • 74 posts
Posted 25 June 2013 - 10:11 PM
Thanks, ordered the part, will separate and try.
