Whirlpool ED2PHEXNQ00 water dispenser on all the time
9 replies to this topic
#1 Jim144
Jim144
  • 11 posts
Posted 25 June 2013 - 04:54 PM
Switch is not stuck - at least I can still hear it click.  It was switching - when I pushed the lever I smelled a faint electrical burning smell and some noise.  Replaced the valve but it still turns on as soon as the unit is plugged in (even with dispenser locked).  I unhooked the wires to the valves as a temporary measure.  Do they put wiring diagrams in these units like on many appliances? Where?
#2 Applianceman97
Applianceman97
    "Hollywood"
  • 2,357 posts
Posted 25 June 2013 - 05:08 PM
Check behind the lower grille. They can be down under the refrigerator
#3 Spannerwrench
Spannerwrench
    Mutsuhito
  • Master Appliantologist
  • PipPipPipPip
  • 952 posts
Posted 25 June 2013 - 05:29 PM
Just because the micro switch clickes doesn't mean it's good. You could have a bad micro switch or a short in the dispenser control.
Tech sheet
https://www.dropbox....S - 2255381.pdf
"Suds are not good"
"Occam's RAZOR 'the simplest answer is most often correct'"
#4 Jim144
Jim144
  • 11 posts
Posted 04 July 2013 - 09:24 PM
Microswitch is good.  For some reason there is 115VAC on the valve side of the switch all the time.  I have disconnected the water valves.  I disconnected the connector at the door hinge and got the same result.  Unplugged the power cord and got 18 ohms between the hot side of the plug and the wire to the water valve.  I disconnected the connector with the temp controls and defrost control in the top of the refer compartment and got much higher resistance but not open - about 4k.  But with only the connectors to the defrost board disconnected (which should be the only other connection directly to the water valve wire) its about 29 ohms.  It seems unlikely but apparently there is a short somewhere in the wiring that runs through the insulation in the side of the freezer compartment.
Any ideas how to check this without disconnecting everything from the chasis wiring ( the icemaker, hinge connector, refer controls area) and then checking for shorts between wires?  Wondering what else might be shorted...
If it is a short in the harness is there any practical way to get to it?
#5 DurhamAppliance
    Sho' Nuff Chozin
  • 5,608 posts
Posted 05 July 2013 - 08:38 AM
You said you disconnected the connector at the door hinge and disconnected the valves and got the same results. Not sure if I am understanding you correctly. What voltage are you getting at the water valve when the dispenser is disconnected at the hinge? And voltage when defrost/water filter indicator board disconnected?
www.DurhamApplianceThrift.com
#6 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 05 July 2013 - 09:01 AM
looking at the wiring diagram, the Water Valve is also connected to the Water Filter Indicator Board
(as an input)
http://appliantology...ge-ed2phexnq00/
#7 DurhamAppliance
    Sho' Nuff Chozin
  • 5,608 posts
Posted 05 July 2013 - 09:19 AM
lol Reg, I just saw that too. I was wondering why he indicated the line went to the defrost control until I looked at the wiring diagram and saw the filter indicator is part of the board.
#8 Jim144
Jim144
  • 11 posts
Posted 05 July 2013 - 10:57 AM
 At first I suspected a bad valve but the valve is working as expected - when it gets voltage (which is whenever the unit is plugged in unless I pull the valve connections) it opens.
With the dispenser disconnected at the hinge I get 115V at the water valve connector (with or without the valve connected).  I still get voltage at the valve connector when I disconnect the defrost/filter indicator board also.
#9 RegUS_PatOff
  • 33,588 posts
Posted 05 July 2013 - 12:04 PM
check the Plug / Connector in the Compressor area
looks like at least a 6 pin Connector
White
Tan
Violet <
Black <
Grn/Yel
Red
#10 PDuff
PDuff
  • 2,045 posts
Posted 05 July 2013 - 12:09 PM
Jim, which connector at the defrost control did you disconnect?  Was it the P1 connector with the yellow, violet and tan wires?  Electrical smell would indicate a short, possibly in that control.  Any other symptoms with the ice dispenser, ice production, cooling etc?
