AARDL
Amana MOD# BBI20TW
4 posts in this topic
Hi All,
I can't find a tec sheet for this unit on Frig or in the downloads.
Mod#BBI20TW  P# P1199101WW
Unit was not getting air into the FF I could not hear the fan so I opened it up no movement from fan I did close the door switch,
I was getting voltage with pen light ( tec 101 mistake make sure neutral is working) so I orderd the fan p/n R0151004.
Well I put it in today and no fan, took meter hot to neutral no voltage.
Need some help.
No wire diagram glued to the rear???..................Check under the front grill..........If I remember , the power is thru the heater element..........Check continuity thru the heater element and thru the defrost terminator/bi-metal..............Use your meter and verify 120 volts A.C. coming into the evaporator area when compressor is operating......................
Hi,
It might be on the back, but this thing is sunk into the carpet, I was thinking that it might be like the side by sides.
I was a little concerned about the black box under the unit.
Thanks Reg
I have to go back out to day thanks again for the help.
