jjcav
Maytag Model LAT9304AAE Washer
4 posts in this topic
Washer is not draining.  I replaced the belts (never were replaced 15+ years).  I was testing the lid switch and broke it trying to test it.  I replace it, still not draining.  What are my next options, any way to test pump?
Is the pump turning when in the spin cycle? You may have a blockage in one of the hoses, either going to the pump or in side the pump. Or you could have a stripped impeller on the pump.
1 person likes this
No the pump is not turning.  I can see the water just moving slowiy in there.  I disconnected the hoses to the pump and the hose to the drum drained free.  I am connecting my vacuum to the hose that drains to see if anything is plug in there.  Next I will remove the pump.  Thanks.  I will let you know how I make out.
I checked the hoses no blockages and the pump is free of blockages.  Disconnecting the pump.
