  • Announcements
tinkertech
Maytag washer Lat5005AAW
3 posts in this topic
My washer has been giving me trouble. First,hardly any cycle would work on it's own. I would have to keep turning the timer selector and jiggling it also. I bypassed what the wiring diagram called the check switch. Now everything works except agitate goes right through rinse and spin. If I turn it off when it reaches rinse or spin and turn it back on it will rinse /spin. Thinking timer,but know it's easy to misdiagnose. Would like any input I can get before deciding to buy a timer.
  Yep, sounds like the timer. After agitate, the motor must pause before it can reverse direction for spin/drain. If it doesn't pause, then it will just continue to agitate through the whole cycle. By turning the washer off/on, you are pausing the motor.
http://www.repairclinic.com/PartDetail/Timer/22001530/454302
Eric
Thank you so much Eric for responding and explaining it so well.Now I can spend with confidence!!!
