bosch oven HBN5650UC
2 replies to this topic
#1 MetalApplianceman
MetalApplianceman
  • 14 posts
  • Flavorite Brew:Budweiser
Posted 27 June 2013 - 10:04 AM
really need a wiring diagram for this oven if anyone could help. the problem is that it seems the cooling fan doesnt run long enough and i dont know where the thermostat is for the cutoff or if it is built into the main control. after the fan shuts off the outer part of the doors get very hot (around 130F). any help would be great.
    Shōgun
  • Master Samurai Tech
  • 30,179 posts
Posted 28 June 2013 - 06:48 AM
Test procedures:  http://appliantology...re-error-codes/
Training Manual: http://appliantology...raining-manual/
#3 PDuff
PDuff
  • 2,034 posts
Posted 02 July 2013 - 02:47 PM
You can test the fan operation in high and low speeds and listen to the fan noise.  Start the oven in a cooking mode: fan should operate at low speed.  Start self clean mode: fan should operate at high speed.  Also check for reversed high and low speed wires at the fan motor.  Make sure the wiring or the upper plenum are not coming into contact with the rubber end cap on the cooling fan.
