JulieJ
JDS8850BDB
4 posts in this topic
I cleaned my oven on the self clean and when finished my Set Up, Oven clean, Warming Drawer key pads stopped working.
All the other key pads work.
The oven and stove top are also working.
What part do I need to order to fix and can I do this myself?
I'm a female and not to mechanically inclined.
Julie
One of the rules of using an oven properly is to never ever use the self clean cycle.
Looks like there's no separate keypad, only the main board to replace.
Part number 8507P230-60
http://www.repairclinic.com/PartDetail/Main-Control-Board/8507P23060/1551088
1 person likes this
Thank you for your quick response.
Is this an easy replacement?
It's not that difficult I don't think. It depends on how you are with a screwdriver. The part itself should be plug and play. Just disassemble the front control panel and remember how it goes back together. Also make sure you unplug before taking it apart.
Here's a part manual with pictures that should help with seeing the parts needed to be removed. The part you will be after is #5 on page 2.
http://appliantology.org/files/file/998-jenn-air-jds8850bdb-duel-fuel-range-parts-list/
