RRW513
Frigidaire gler642as3 drum won't come out!
5 posts in this topic
Our gler642as3 dryer is not drying clothes well. It runs about 3 hours before the clothes are anywhere near dry. The vent is clear and air blows just fine out of the back of it so we don't think it's an air flow issue. The clothes do not feel hot when we take them out so we believe it's not getting hot or not hot enough. They do feel a little warm and I do feel the back of the dryer getting hot, but I'm thinking that the only issue it could be is the heating element. If you have any other suggestions as to what it might be, that'd be great.
However, I decided to disassemble the dryer and see if the thermal fuse was the issue or if it was the heating element. I had not one problem taking the machine apart using a instructional video. Only when it came time to remove the drum, it wouldn't come out! It feels like it's still attached firmly to the back of the dryer in the very center of the drum. I tried looking up info for this specific dryer and the only thing I can find is the same instructions that are everywhere for all dryers, nothing specifically for ours. I lifted the lid, detached the wires, took the front off, then took the back piece off and detached the belt.
Is there something special about this dryer that makes it so I have to do something else? I see there are a bunch of screws on the back of the drum, but I didn't want to remove those for no reason and end up making things worse. I did remove all the screws on the back of the dryer, and that made no difference. My husband thinks it's crazy every time I try and repair stuff in the house myself. He'd rather pay someone $150 (actual quote from a repair man) to fix it.  So now I look like an idiot because our dryer is taken apart, and I have made no progress toward fixing it. My husband wants to just put it back together and pay the crazy repair fee. Any advice on what I might have missed? I really hate the idea of paying someone money to do something that I can do myself.
You need to push up on the drum to release the drum bearing in the rear, usually it's just a simple push up, but I've occasionally had a few where you have to smack the inside of the drum upwards with the palm of your hand. Don't take the screws out of the back, no need.
But you said the dryer gets hot on the outside back panel? Very your air flow isn't the problem. Test by running a load with the vent hose disconnected from the wall. But don't do this a lot, just for a small quick test load.
I jut tried asking my husband to pull up on it hard, and it's not moving. There are 3 screws in the middle of the drum that I'm tempted to unscrew but I don't want to mess something up. We tried running it disconnected from the wall and with the hose disconnected, this is how we knew for sure it wasn't the vent or the hose that's clogged and because there's a good amount of air flowing out of the back we concluded it wasn't the air flow that was the issue.
My husband manage to get it out, it took way more muscle than I would have ever thought. It looked so simple in the video.
Here's the parts breakdown, look on page 2. What you're trying to do by popping the drum up is lift #32 up out of #12. It can be done. If you take the screws out of the rear of #21 you are unscrewing the drum from #32, you will still need to remove 32 from 12. It's just more work doing it that way.
GLER642A
http://appliantology.org/files/file/996-frigidaire-dryer-gler642a-parts-list/
