Washer leaking from underneath.....kenmore model # 417-40042990
9 replies to this topic
#1 pattigreen
pattigreen
  • 5 posts
  • Flavorite Brew:Stella
Posted 28 June 2013 - 03:12 PM
I have a Kenmore stackable washer/dryer.  The washer is leaking from underneath.....I think during the spin cycle but not sure.  Initially it only happened on large loads but now it seems to be leaking every load I do.  Would sure like to repair it as opposed to purchasing a new set.  Kenmore no longer makes the washer that goes with my dryer so I would have to replace both. Ugh!
#2 Strathy
Strathy
    Head Wrench
  • PipPipPipPip
  • 762 posts
  • Flavorite Brew:Coffee
Posted 28 June 2013 - 03:56 PM
The 1st thing I would check would be the door boot.  Open up all the folds on it and make sure you don't have a tear or a cut up one of the sides.
Neighbour's Appliance Service
Servicing Southern Manitoba, Canada
#3 pattigreen
pattigreen
  • 5 posts
Posted 28 June 2013 - 04:02 PM
No...the door boot is fine.  That was the only thing I could figure out to check when it first started happening......I did find 85 cents though!
    Shōgun
  • Master Samurai Tech
  • 31,193 posts
Posted 28 June 2013 - 04:06 PM
Remove the panel below the door and run the washer while you babysit it with a flashlight and a Bloody Mary. The source of the leak will soon reveal itself. Do tell.
#5 Spannerwrench
Spannerwrench
    Mutsuhito
  • 1,127 posts
Posted 28 June 2013 - 04:11 PM
As the Samurai always says, leaks are always visible.
"Suds are not good"
"Occam's Razor 'the simplest answer is most often correct'"
#6 pattigreen
pattigreen
  • 5 posts
Posted 28 June 2013 - 04:19 PM
It's 102 here today.....I think I'll make a gin and tonic and camp out in front of the washer.  Great advice/both the washer and the beverage....Thanks!
#7 pattigreen
pattigreen
  • 5 posts
Posted 28 June 2013 - 05:12 PM
OK.....I can see the leak and there are 2.  there is a gray, hard plastic pan of sorts that has 5-6 bolts, that I can see, in it.  It's  kind of the same shape as the washer tub.  It has a slow steady drip from 2 of the bolts.  Is it possible to tighten the bolts (octagonal head).....if so I need to get a proper tool.....or does it sound as if that part is shot and needs to be replaced?
Definitely going to need an additional G & T for this job.  I will start mixing while waiting for a response.   :wacko:
#8 sh2sh2
sh2sh2
    Senpai
  • PipPipPipPip
  • 849 posts
  • Flavorite Brew:yeunling
Posted 28 June 2013 - 05:42 PM
picture?, sounds like its leaking from where the tubs bolt together, try tightening the bolts and see if it helps
#9 pattigreen
pattigreen
  • 5 posts
Posted 28 June 2013 - 06:24 PM
I actually think it is leaking all along the seam but just dripping at the bolts.  The bolts are completely tight....no slop at all.  Tried to look underneath, with a mirror, at the seam but it's impossible to see.....especially during the spin cycle.
When the washer goes into the final spin it spray everywhere and a lot more water is forced out.....enough to puddle on both sides and front of the washer.  I may need to learn how to lay a new floor if I ever get this fixed!
Took a photo but can't, for the life of me, figure out how to attach it.
Is it possible to replace that entire plastic part?
#10 Budget Appliance Repair
  • Senior Appliantology Fellow
  • 5,149 posts
Posted 29 June 2013 - 07:39 AM
You just need to tighten all the 20 or so bolts holding the two tub halves together.
It's not usually the ones at the bottom that start loosing up, (or the heads actually start digging into the plastic then letting the tub halves separate), the leak just appears at the bottom because that is were the water flows to.   You will usually see signs of splatter on both sides of the cabinet if it has been leaking for any length of time.
After removing the dryer off the top and remove the lower kickplate you should be able to reach all the bolts without taking anything else apart.  If I remember correctly those bolts have a 3/8" head.
William Burk (Willie)
Eureka, CA 95501
