Kokanee Ranger
KGSS907SSS 00 Not sensing flame , shorted somewhere.
5 posts in this topic
Changing DSI did not change any thing. W10331686
I have continuity but hight resistance L1 and N to the body of the unit.
Was advised to change the harness . But I suspect the appliance manager.
What are the symptoms you are having with the range?
In preheat the flame will go out at least once . With a Pop , click,click,click.
When up to temp. will reignite about once every minuet .
Originally found 0.0 Vac Green to Tan and 53 Vac green to White on DSI . Advised to change DSI
Replacement DSI now shows 53Vac at Green to Tan and 53 Vac green to White on DSI
Now origenal DSI shows 53Vac at Green to Tan and 53 Vac green to White . !?
Tested from the plug , L1 to unit body continuity , unplugged the harness No continuity .
Short in the harness or the Appliance manager.
... Originally found 0.0 Vac Green to Tan and 53 Vac green to White on DSI .
... Replacement DSI now shows 53Vac at Green to Tan and 53 Vac green to White on DSI
... Now origenal DSI shows 53Vac at Green to Tan and 53 Vac green to White .
those are High Voltage Spark outputs .. can't be measured
For BAKE, measure DSI input for 120v AC from Black to R/W
For Broil, measure DSI input for 120v AC from Black to BU/W
There may be a problem with the Bake Burner / clogged
