how to connect rod to the damper control in the refrig section
6 replies to this topic
#1 desba
desba
  • 4 posts
Posted 29 June 2013 - 09:24 PM
Hi,
I was having issues with the fridge not cooling well. I removed the damper control to check for blockage. I am now unable to reconnect the rod (the rod connecting the dampre to the freezer tep. comtol dial) to the grey assembly because the rod is pushed upward when I try to insert the rod into the hole in the assembly. Do you know how this can be reattached?
Dennis
Sorry I forgot to mention the model. It is a Whirlpool DesignerStyle ETZZDMXBW00.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 30 June 2013 - 01:13 PM
ETZZDMXBW00
maybe
 ET22DMXBW00 ?
#3 desba
desba
  • 4 posts
Posted 01 July 2013 - 11:08 AM
Hi.
Yes thanks for catching that. The model number is ETZZDMXBW00.
#4 RegUS_PatOff
  • 33,588 posts
Posted 01 July 2013 - 11:34 AM
maybe
 ET22DMXBW00 ?
#5 desba
desba
  • 4 posts
Posted 01 July 2013 - 12:11 PM
Sorry I cut and pasted the same. Yes the model is ET22DMXBW00.
Thanks again
#6 RegUS_PatOff
  • 33,588 posts
Posted 01 July 2013 - 12:40 PM
I don't know if this will help
for reference
#7 desba
desba
  • 4 posts
Posted 01 July 2013 - 01:44 PM
Thanks for the reference but the issue is the rod goes upward when I try to put it into the baffle hole connection. The rod is light and just raises into the slot where it comes out of the top of the fridge when i push on it with the grey baffle attempting to connect it.
