dryerman45
WHIRLPOOL DRYER
13 posts in this topic
Hi SAMURAIS,
Ihave a whirlpool dryer model# WED5100VQ1.The customer says it works fine in timed dry but doesnt dry clothes hardly at all in auto dry.The timer is advancing in the auto dry mode and will complete the cycle but clothes are not dry.
Help appreciated
SAMANERA
Vent problem.
could be the Timer
could be a Vent problem
Dryer Vent 4" diameter
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
$ 3.99 sometimes on sale for $ 2.99
Easiest check is to use a green scrub pad (the one you use for dishes) and clean off the sensor bars inside you dryer... Open the door Stick your head inside the drum and look at your toes. They are two bars about 4 inches long and parallel to each other. Also everything above is valid too.
I replace that same China timer weeks ago for no heat broke.Took It apart and still could not see any burnt contacts and jump it out and got heat.Worse timer i ever saw.But saying that your going to have to check everything out to get to that point.
No Sensor Bars on this model.
Also l like to test cycling thermostat with the vent on and back panel off with a voltmeter or as i use a neon test light that i made up out of a G.E #WB2x1608 neon light with alligator test leads and see if it is cycling on the right thermostat .And sit there and watch it cycle.
same Thermostat used for Regular Dry and Auto Dry
look at the wire diagram, is there a big resister inline with the timer??? about a 5000 watt resister.....The resister is located in the console, some look like a small sound coil.................
Moved from the Kitchen to the Laundry forum.
I suspect the timer .
It my have different contacts to power heating circuit.
I would test Black “C” to Red “A” at the timer for continuity.
With timer set to timed dry and then autodry.
Saw this on an old Maytag once. Just sayin.
