ebohatch
Kenmore HE2 failing
3 posts in this topic
I have a Sears Kenmore HE2 front loading washer Model # 110.46472501
It is failing to perform. There is no diagnostic LED just the various lights next to Status or wash selection.
I can set it to Drain & Spin it will start to drain then after a moment will turn the drum in one direction a few revolutions stop for a moment then turn the drum in the other direction for a few revolutions after a while it will start flashing all the lights around the wash selector knob, they will flash on for about a second and then off for about a second. The status lights for Add a Garment and Wash are off, Rinse, Spin and Clothes Clean are all on.
I took the back off and checked the interior is very clean, the belt looks to be in perfect condition. I can manually move the drum very easily.
Any idea as to what is wrong?
Does the door lock? Take the lower front cover off and open the pump to see if it's plugged, you will loose the water so be prepaired.
1 person likes this
Yes the door locks. Yes I have already removed the filter and cleaned it out.
It does appear to drain correctly.
