saloonsailer
kenmore dryer #11060982990 won't run when start button released
14 posts in this topic
checking through previous posts it would seem that the problem is "even heat control board"
My question:Is this this an assured diagnosis and are there probable contributing factors or  is there anything else to check before ordering this little ($187) gem.
Edited by saloonsailer
The even heat board is a common failure, and a match to your symptoms. Get the part from Repairclinic so you could return it if not needed.
Diagnostic details on the even heat board are here:  http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
Brother nick speaketh much truth.  Here's the part link to the even heat board:  http://www.repairclinic.com/PartDetail/Dryness-Control-Board/W10116564/1480790?modelNumber=110.60982990
Dryness-Control-Board-W10116564-00797464
Or to just the relay if you're able to to determine that the motor relay is bad:  http://www.repairclinic.com/PartDetail/Relay/3405281/528722?modelNumber=110.60982990
Easy way to tell is to swap it out with the heater relay and see if the motor runs normally (but the dryer won't heat).
If it doesn't fix your problem, return it for a refund, even though it's been installed.
looking at the wiring diagram,
the EvenHeat Board controls the Timer Motor, not the Drum Motor
and I don't see a Relay
Good catch, Reg-- I just now checked the wiring diagram you posted and you are correct.
I think saloon is looking at a bad motor:  Part number: AP3094233
Yes ,the drum turns normally when button is pressed, I have read the links suggested and will try suggested procedures,
Thanks for the input, i have my multimeter in hand and should know more in a few minutes!!
the confounded control relays and "evenheat" self destruct board,are indeed marketing genius
now I'm confused! (that didn't take much)  did not see the "MOTOR" reference,though from a monitary point it would be a gain. I am tearing the dang beast open, check in with you a little later, thanks again.
whoa boys!! it would seem the wiring diagram, postedby "REG ", is for  gas dryer, wrong number, mine is the 110 6098 2990 electric
Drum tumbles OK while Start Button is held ?
Clean out the lint in the Drum Motor Centrifugal Switch
same tech sheets as
http://appliantology.org/files/file/832-kenmore-dryer-gas-11070912990-wiring-sheet/
did you download and take a look at the tech sheet(s) ?
It's for both gas and electric-- two different diagrams.
thanks, i didnt get past the "gas dryer" intro page. i'm just home from work and can go into it, including the centrifuge switch lint check.i did look at the wiring diagram, haven't got it straight ,but will. appreciate you guys .
Could be the centrifugal switch in the motor is just stuck.  Try pushing the switch body near the rotor with a small flathead screwdriver to get it to disengage.
would the cientrifugal switch be the 2" flat black one with 2 wires adjacent to motor wire flat connecter?
O K , i have the drum out checked all the small electric parts, all good it would seem that the mechanical switch on motor shaft moves fine, dont know how to prove it works electricly, thats why I was asking about the (seperate connector with two blue wires) . can i effectivly check the centrifugal switch function here ?
