Oven will not light - SF114PXSB1
5 replies to this topic
#1 BEdwards
BEdwards
    Sōhei
  • Chief+ Appliantologist
  • 158 posts
Posted 01 July 2013 - 01:05 PM
Went to home today and found the oven would not light. Tested the igniter and only drawing 2.9 amps. Bad igniter. Replaced igniter and still would not light. New igniter drawing 3.1 amps. I assumed bad igniter out of box, so I pulled another one out. Same thing. I am assuming that means there is some internal resistance problem in the gas valve, right??
No tech sheet in the oven, so if one is available that I could put back in the oven that would be great.
<p><a data-ipb='nomediaparse' href='[url="""]http://www.gfyappliancerepair.com'>Appliance[/url]Repair Winder GA</a>
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 01 July 2013 - 01:09 PM
... New igniter drawing 3.1 amps.
measured after 30 seconds ?
flat Ignitor ?
#3 BEdwards
BEdwards
    Sōhei
  • 158 posts
Posted 01 July 2013 - 01:10 PM
flat Ignitor ?
yes, gave it 30 seconds.
yes, flat bar igniter.
#4 RegUS_PatOff
  • 33,588 posts
Posted 01 July 2013 - 01:15 PM
Gas Safety Valve should be .92 OHMS
3.0v to 3.3v
#5 Budget Appliance Repair
  • Senior Appliantology Fellow
  • 5,047 posts
Posted 02 July 2013 - 07:33 AM
Make sure the little lever on the side of the regulator hasn't got bumped into the "Gas to oven OFF" position.
I'm pretty sure lever raised pointing straight out is ON, resting flat is OFF.
William Burk (Willie)
Eureka, CA 95501
    Shōgun
  • Master Samurai Tech
  • 30,708 posts
Posted 02 July 2013 - 08:08 AM
3.1 amps is close enough to the spec that I'm thinking that's probably measurement error.  I can get 0.3 amps variance in the reading just by changing exactly where the wire is positioned within my amp meter jaws.
I think Willie done called the ball on this one.
