KitchenAid Dishwasher KUDS30IXBL0 stops running
37 replies to this topic
#21 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 30,926 posts
Posted 09 July 2013 - 04:20 AM
 How do I donate to the site? Is that with PayPal?
Love offerings to the Beer Fund are gratefully accepted via Paypal:  http://beer.fixitnow.com/
#22 elwood13
elwood13
    Ikkō-ikki
  • 22 posts
Posted 10 July 2013 - 08:27 AM
Will do. This may be a stupid question I just thought of, but which way is the interior vent cap suppose to face? With the vent blades facing up or down? I can't remember if it only goes one way and I'm at work right now, so I can't check.
#23 Spannerwrench
Spannerwrench
    Mutsuhito
  • 1,099 posts
Posted 10 July 2013 - 02:20 PM
The notch goes to the bottom.
"Suds are not good"
"Occam's Razor 'the simplest answer is most often correct'"
#24 elwood13
elwood13
    Ikkō-ikki
  • 22 posts
Posted 10 July 2013 - 04:07 PM
Thanks spannerwrench and I do like crown royal as well.
#25 elwood13
elwood13
    Ikkō-ikki
  • 22 posts
Posted 22 July 2013 - 10:47 AM
This thing is driving me nuts. Put the new vent on. No water . Ran the first cycle fine, but noticed a little water/suds in the bottom. Hit the drain button and it emptied. Ran the next cycle and the same thing. Took the cover off the drain and all looked good. Checked that the discharge line and it was clear. Ran again, same thing. Ideas?
I thought I rotated that picture. Sorry its upside down
#26 elwood13
elwood13
    Ikkō-ikki
  • 22 posts
Posted 22 July 2013 - 03:18 PM
Forgot to add. It holds that amount of water each time and I have ran it on 1hr wash and eco wash with the same results. It says it completes the cycle and give a green finish light.
Thanks for correcting the picture.
#27 bigbuck
bigbuck
    Sōhei
  • 236 posts
  • Flavorite Brew:Red Wine
Posted 22 July 2013 - 03:59 PM
One drop of non dishwasher soap will give you suds.Or like in the other posts your rinse aid tank maybe leaking or putting it in at the wrong time.Do you just rinse your dirty dishes off with water.Do not soak dirty dishes in non dishwasher soap.
#28 elwood13
elwood13
    Ikkō-ikki
  • 22 posts
Posted 22 July 2013 - 04:56 PM
I always rinse them with just water because it takes a little bit for the hot to reach the sink. I think the jet dry is empty, but I guess you have to take it off to be sure. I use the jet dry because our water spots everything. I think the drain area looked pretty clean for just opening it up. You can see the suds floating on the water in the center. Shouldn't that drain out? Also it didn't run a full cycle last time on eco. Any way to test the control board?
#29 Kokanee Ranger
Kokanee Ranger
    Yamabushi
  • 61 posts
  • Flavorite Brew:Kokanee ... the beer out here.
Posted 26 July 2013 - 08:38 PM
Drain pumps are designed to pump water not suds . All your water is turning to suds , after the dry cycle most of the suds have turned back into water and thats what you see.
You should be able to detach the black panel off the front from the control panel.
Reattach the latch and control to the inner panel. Closed the door and run a quick or 1 Hour cycle.
Now grab a beer .. maybe two and watch the dispenser. Whether it has a wax motor or a cylinoid.
It should only activate twice . First time to release detergent in the wash cycle and once more in the rinse cycle for your JetDry.
If it is activated more the twice then it is your control.
Only twice you have a leaking dispenser.
Leaking dispenser is the more likely cause , But I have seen a bad control One time !
#30 elwood13
elwood13
    Ikkō-ikki
  • 22 posts
Posted 27 July 2013 - 08:27 PM
Thanks Kokanee. I was gonna give an update an ask a question, but think you already answered it. I cleared the diagnostics and ran it again. This time no suds, but the jet dry was empty. I was wondering how to test that part and if I'm reading you right, I'm basically running the washer without the cover on to watch the dispenser.
That still leaves me with why will it stop during a cycle and is it normal for water to be left in the bottom? I know samurai said one step at a time, so ill do the dispenser next.
#31 elwood13
elwood13
    Ikkō-ikki
  • 22 posts
Posted 07 August 2013 - 05:56 PM
Okay....the saga continues. Life has gotten in the way, so I ordered a new soap dispenser since the consensus is that it is leaking which I agree. Once it was empty, the suds went away. Put the new one and ran the eco cycle. It shut off sometime during the cycle and now I am back to the original main problem. I think I cleared the error code last time, but it stilled showed a 6-1 and 6-2. I'll try and run a diagnostics again tonight, but not sure if the old codes are clearing. Is this a junky dishwasher? Should I throw in the towel and just get a new one? Thanks so far for your help.
#32 Spannerwrench
Spannerwrench
    Mutsuhito
  • 1,099 posts
Posted 07 August 2013 - 06:03 PM
Run it with no detergent and no rinse agent and see what happens.
"Suds are not good"
#33 elwood13
elwood13
    Ikkō-ikki
  • 22 posts
Posted 07 August 2013 - 06:14 PM
In the process as we speak. When I did the first run after installing the new dispenser, I did not add any jet dry to the dispenser, so it is still clean. I just cant figure why the thing is shutting off mid cycle. I pressed the hi temp key in interval 20 and 13 last time to clear the codes. I hope thats correct. Thanks Spannerwrench. I'm running on the 1 hour mode right now and will get back with you later. One thing is for sure, I can get that front panel off pretty darn quick now. lol.
#34 Chat_in_FL
Chat_in_FL
    Havoc
  • 1,566 posts
  • Flavorite Brew:What's on tap?
Posted 07 August 2013 - 07:26 PM
W10398386
Customer Concern: Dishwasher stops approximately 10 minutes into the cycle, “cancel drains” and goes directly to standby mode (off).
Cause: Testing has determined that cycle stopping may result from a software error that can cause a false error code that cancels the cycle. Techs will see a 6-1 error code recorded in service diagnostics. This issue is very sporadic, and is affected by the location of the household and region of the country.  Other conditions that may also cause this “cancel drain” cycle are: siphoning through the drain hose, severe sudsing, and debris in the sump.
Correction:
If the customer experiences a “cancel drain” issue, first check the following:
1. Make sure the dishwasher is installed according to installation instructions provided with the unit.
2. Check for water siphoning out through the drain hose. Ensure that the drain hose end termination point
is above the water level in the tub. The drain loop attached to the side of the tub is not sufficient to
prevent siphoning.
3. Check for severe sudsing or a malfunctioning Rinse Aid dispenser.
4. Check for locked rotor in wash pump.
5. Check for and remove debris in the bottom of the sump/chopper area.
6. Check for water supply and proper water level in the dishwasher.
7. If all the above checks are OK, then the control will need to be replaced with one that has the upgraded
software designed to handle any additional power variation. See chart below for part numbers.
Control Part Number
W10195347
W10195348
W10380684
W10380685
Replace with Part Number W10380685
Mother Teresa
The views and opinions expressed in this post are those of the author and do not necessarily reflect nor represent the views and opinions held by my employer. All data and information provided is for informational purposes only.
Big Brother
#35 elwood13
elwood13
    Ikkō-ikki
  • 22 posts
Posted 07 August 2013 - 08:52 PM
No suds in either run. Had the 6-2 and 6-1 in the customer error slots and no codes in the service error slots.
Thanks Chat... Let me go over them one by one.
1) I followed the instructions on installation and did not have any problems until the unit was over two years old. Could I have still put it in wrong?
2) I believe the drain line runs into my disposal as I can see the water enter when the drain cycle comes on. Couldn't tell you if I have a loop in it because I don't remember.
3) Replaced with new dispenser and no suds. Removed soap from old one and then no suds.
4) Not sure how to do this one.
5) It was clean as per the pics.
6) How do I check for proper water level?
It's drained completely the last several times, but the few that did not showed the green light for the end of cycle.  Today I know it shut off within an hour, but couldn't tell you the exact time.
This problem has been sporadic for the last several month, but got worse when I started this thread.
#36 Samurai Appliance Repair Man
    Shōgun
  • 30,926 posts
Posted 07 August 2013 - 09:41 PM
http://www.repaircli...0380685/1938381
#37 elwood13
elwood13
    Ikkō-ikki
  • 22 posts
Posted 08 August 2013 - 06:56 AM
A new control board it shall be. Thanks, and I will keep you updated.
#38 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 08 August 2013 - 07:13 AM
Gasket   W10469575  is the corect number .
5 . . . W10195031 Vent Assembly
http://www.repaircli...R=154&N=2210048
(Also Order Item 6)
6 . . . 8269259 Gasket, Vent
http://www.repaircli...?R=154&N=830951
