GCT123
GE Dishwasher Overflows into Spillway, Triggers Pump and 'Heated Dry' Light
7 posts in this topic
Hi,
My GE Monogram dishwasher (model ZBD5700) seems to have a sporadic 'over fill' problem.  During the rinse cycle, near the end of the run, water will sometimes run down the spillway into the small overflow tray, causing the float to rise and the pump to kick on.  This is accompanied by the flashing 'Heated Dry' light.  The only way to stop the pump (and the light) is to manually empty the overflow tray.
I've check the water level, and it was below the 'Max' line.  Just to sure the water level wasn't the problem I reset the 'fill time' to the lowest setting - 75 seconds (factory setting is 80).  The water level is at the 'Min' line now (or maybe a little below).
I've watched underneath while the dishwasher runs and it goes through some of the fill/drain cycles without any issue (not sure how many fill/drain cycles there are).  Then, possibly in the final rinse (or near the end anyway) the water runs down the spillway.  I don't understand why it's happening, and why it doesn't happen every time.
I don't see any food/debris anywhere, and there isn't excessive detergent being used (in fact it happens with no detergent at all).
Any advice would be greatly appreciated!
Greg
Haven't had any experience with this unit.  My first thought was oversudsing since the detergent dispenser doesn't open until the final wash cycle.  But if it leaks without detergent then problem lies elsewhere.  Was looking at that sump 4 stage filter which has been discontinued.  Double check venture and spray arms for any cracked or debris.  Will continue research on this end.
Thanks for your reply PDuff.  I don't see any cracks or debris.  Does the pressure switch control the water level?  If so, could the pressure switch be malfunctioning sometimes?  I disconnected the hose to the pressure switch and it was clear.  I blew into the switch and can hear it operating, but I'm not sure if that really proves it's working correctly.
Thanks for continuing to research.
Drain pump may be intermittently failing or doing incomplete pumpouts causing an overfill at the next fill.
Ohms check on drain pump:  35 ohms ± 10%.  But this is not definitive, merely preliminary.  Can check good on ohms but still be bad (failing under load).
Check basin between cycles for complete pumpout/water left behind.
Service manual:  http://appliantology.org/files/file/1022-ge-zbd5900-zbd5700-zbd5600-dishwasher-service-manual/
Thanks Samurai, I think you're right about the drain pump.  Now it's not draining at all.  The pump is making kind of a humming/groaning sound continuously.  It continues to run unless I leave the door open (I haven't tried resetting the breaker yet).  The light blue 'box' on the side of the pump is pretty hot (not sure if that's normal).
So does it sound like the whole pump unit is bad, or could it be some component of the pump?
Is the drain pump difficult to remove/replace?  It looks like it screws off from the sump housing (after disconnecting the drain hose and wires), but there doesn't appear to be enough clearance to rotate the entire unit.
