precision1971
Samsung Washer M# WF331ANW/XAA SR Error Code
2 posts in this topic
Hey Guys
I've been trying to get this washer going for a couple days now.
Its displaying the SR error code which is supposed to be a bad relay on the main board.
The code oddly seems to set when the washer is in the off mode.
I replaced the main board and reset the EEPROM but still has the same problem.
I also checked for stuck buttons on control panel and bad connections at board and couldn't find any.
The machine can be programmed and the door will lock but it won't fill, tumble, spin, or drain.
I worked on it for 1.5 hours yesterday and couldn't figure it out.
Could anyone point me in the right direction?
SR Switch Error
Check whether either the Power switch or a tact switch (any button) is stuck down.
Check whether the service PBA holding screws are fastened too tight pinching the contacts
If the main PBA switching IC on/off error has occurred, replace the PBA.
The “E2” error occurs if the main relay connections are incorrect.
Check the connections. If there is no error in the connections, replace the main PBA
Edited by Spannerwrench
