The days of Monkey Boy Service Calls are over...
Click here to check out our fun short course and learn how to get the most out of Appliantology.
herfdog
Kenmore dryer 796.80272900
6 posts in this topic
I was wondering what the operating temps for this dryer should be? I set it on high and cycled it a few times before checking the temps, it was cycling between 141º and 157º at exhaust duct disconnected from house. The complaint is "not drying well", cleaning the house ducts today.
thanks
Dryer Vent 4" diameter
Vent should be rigid metal.
NO plastic
NO PVC
NO screws
Foil Duct Tape is OK.
Check / clean the Dryer Vent
Thanks for the temps
Temps are about right.  Can check the dryer vent using this nifty gizmo:  http://www.repairclinic.com/PartDetail/Tester/W10106710/1447456
Very useful for giving objective proof of a dryer vent's condition to a skeptical customer.  It rolls with the regular tool compliment on The Guru Mobile:
How is the front bearin/ glides? If the drum isnt sealing properly, it could also cause an airflow problem.
Edited by micabay
Thanks for the tips and especially the temps, that confirmed my suspicion that the house vent was the problem. Cleaned the vent and now have a happy customer.
BTW that is one cool tool, you've strummed the strings of this appliantologist. I like the idea of turning suspicion into confirmation.
