bogreen
Whirlpool Duet Washer Model #GHW9150PW1
4 posts in this topic
Hi,
This unit gets to the 12 minutes left area and then gives a "suds" code for about 4 minutes and then gives an F02 code.
Pump drains all the water out. Pump clean out is free of debris. Actually quite clean.
I ran the Diagnostic Test and it performed fine until the last high speed cycle at which point it
just stopped and did nothing further.
The Tech sheet says it's the pump.
But, based on the Diagnostic Test, I would suspect the CCU.
Comments??
Bruce
check the pressure switch hose for cloggs
Go with the pump, not pumping to specs
