whirlpool duet front loader
3 replies to this topic
#1 gary123
gary123
  • 5 posts
Posted 05 July 2013 - 05:20 PM
hello guys
             i have a whirlpool duet model #wfw9470ww01 when you try to wash in normal or any cycle besides rinse & spin it doesnt get enough water and gives code f20  but if you use rinse & spin it get enough water can you tell me where to look to fix this problem
        thanks Gary
        hobbs_g @bellsouth.net
#2 Thirstytech
Thirstytech
    Kohai
  • Master Appliantologist
  • 418 posts
  • Flavorite Brew:Greenbush Starchicken Shotgun
Posted 05 July 2013 - 05:26 PM
Welcome Gary!  For starters I'd shut off the hot and cold water valves then remove the supply hoses off the back of the machine and check for screen clogging debris at the inlet valve.
With the hoses removed also a great time to verify water pressure from the house.
#3 gary123
gary123
  • 5 posts
Posted 05 July 2013 - 05:59 PM
hello thirstytech i have tried to remove the hoses nothing clogged plenty water pressure  why would it work on rinse & spin & not on regular wash??
#4 Thirstytech
Thirstytech
    Kohai
  • 418 posts
Posted 06 July 2013 - 03:12 PM
Here are the next steps:
https://secured.whir...2574500049997b/$FILE/duet_f20_code.pdf
