saaman
Amana Side by Side ARS9169as Will Not Cool
14 posts in this topic
I have an Amana Side by Side ARS9169as that will not cool or freeze.  Also no water comes out the door.
A couple of years ago I replaced the defroster thermostat and it worked fine.  Now it started acting up the same way.
Is this the same problem.  Also will the regfrigerator operate if I take out the thermostat and do not replace it?
Compressor operating??????......remove the evaporator panel and get your eye balls on the coils....You are  probably low on refrigerant........Low side leak............
No leak and the fan is running.
When I manually turn the thermostat the fan stops.
Any frost on the coils?is compressor running?Condenser fan running?Any clicking going on?
Edited by bigbuck
It is built in and I can't get to the back to see
Evaporator  coils , behind the panel in the freezer section..........Is there frost on the coils?????......Is the stile hot?????...........The part in between the doors......................
If you are certain you don't have a sealed system failure.. here is some food for thought :
I had an amana where a faulty timer caused cooling problems as well as the water not to dispense. The problem was electrical and intermittent. I'm no electrical wiz but I think there must be a nuetral(?) line to the dispenser that runs to the timer/connector. My cooling problemwas not related to a defrost or sealed system failure. Maybe a faulty timer/connector sends interference to the fan as well as the dispenser. All i know is the problem stopped when I replaced the timer. Haven't looked at the diagram, but the timer I worked on was located under the fridge. I think condensation or water somehow can get into a timer located under the fridge.
No frost on the coils.  It has started cooling again so the part between the doors is starting to get cold.
check to see if your water line is frozen.
Water is coming out and it is cold
The stile should be warm, it is in line after the condenser and before the filter dryer.......The defrost timer is in a little box  behind  toe grill.....Can be seen looking from the right........Evaporator fan operating and  condenser fan operating?????????..........................Find the wire diagram in case we need it later......
How are you determining you don't have a refrigerant leak?
refrigerant leak - sorry for the miscommunication - I was looking for water leaks.  I do not know if there is a refrigerant leak
The lower part of the freezer is getting cooler.  The fridge is still warm.  There is no air flowing through the vent from the freezer to the fridge
