Sub Zero 642/S3 Serial M2679264: No power to fridge compressor, Freezer not at temp
5 replies to this topic
#1 AlexM
AlexM
    Kohai
  • Chief Appliantologist
  • 378 posts
  • Flavorite Brew:Root Beer
Posted 06 July 2013 - 11:35 PM
This 642 has temps around 18f at freezer and 45f + at FFside.  The compressor for the freezer runs fine, the compressor for the FF is cold and there is not 120vac at the wires to the relay.
The display says 'Service' and there is a EC on the right of the display where the temp should be for the FF section.
I found the control board test sheet and ran all the test listed, seems I got 120vac at every test that I was supposed to get 120vac.
I couldn't get any other error codes other than EC and service to show up on the display. Are there some test points on the board I can check for the compressor and wouldn't that tell me if its the board, or something else?
Does anyone happen to have the service manuaul?
Thanks in advance.
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 07 July 2013 - 02:33 AM
http://appliantology...0-3-sn-2600000/
#3 Spannerwrench
Spannerwrench
    Mutsuhito
  • 1,073 posts
Posted 07 July 2013 - 11:53 AM
It looks like neither the fresh food nor the freezer sections are at the correct temps. The only thing, besides the control, that they share in common is the condenser fan motor and the condenser coil housing. Make sure the coils are clean and that the fan motor is running full speed.
Edited by Spannerwrench, 07 July 2013 - 11:54 AM.
<p>"Suds are not good"<br>
"They write directions for a reason"<br>
"Make sure you're using it right before you say it's not working correctly"<br>
"If if has a Diagnostic Test Cycle, Run it before and after you fix it!"<br>
"Doing the same thing over and over again and expecting different results is insane"<br><span style="color:rgb(0,0,0);"><span style="font-family:'Helvetica Neue';">"For every complex problem there is an answer that is clear, simple, and wrong."</span></span></p>
<p><span style="color:rgb(0,0,0);"><span style="font-family:'Helvetica Neue';">"Occam's RAZOR </span></span><span style="color:rgb(56,57,57);font-family:Montserrat, sans-serif;">'the simplest answer is most often correct'"</span>
#4 AlexM
AlexM
    Kohai
  • 378 posts
Posted 07 July 2013 - 01:03 PM
Good point, the fan was running but maybe not at the correct RPM's?
The condensor was not very dirty, and I was so hell bent on addressing other options I didn't bother cleaning it.
The fact that the compressor relay and overload tested good and the Ohms on the compressor studs tested 'normal' and I didn't have voltage at the wire's leading to the compressor made me think it was a board issue or thermister?
#5 certified tech group 51
  • 2,694 posts
Posted 09 July 2013 - 09:03 AM
Voltage out of control board???..( Looks like Terminal E6 )..............gray wire going to the compressor........What is the voltage, terminal to a good ground/frame....................Close the refer  fan switch, does the evaporator fan motor operate?????........Both are wired to the same terminal on the control board, gray wire...........Clean the condenser coils........
#6 PDuff
PDuff
  • 2,091 posts
Posted 09 July 2013 - 11:36 AM
For this model and series if there is no code shown with the "EC" and "Service" flashing then the "EC" display indicates excessive compressor run time for that particular section.  You can check thermistor temperature readings by initiating the diagnostic mode as follows:
1)  Unit must be on.
2)  Press Colder and Unit On/Off key simultaneously then release both keys.
After performing the above key strokes, the following will appear on the LCD.  Temperatures shown are for reference only, actual temperatures may vary.
-05          SERVICE (Illuminated)          F
(Temperature of freezer compartment)
40           SERVICE (Illuminated)          r
(Temperature of refrigerator compartment)
-12          SERVICE (Illuminated)          FE
(Temperature of freezer evaporator)
29           SERVICE (Illuminated)          rE
(Temperature of refrigerator evaporator)
Pressing the Colder key at this time will take the display back to the first reading, freezer compartment temperature.
Note:  If "EE" is displayed in place of temperature, the thermistor in that location is faulty.
Diagnostic mode will end 10 seconds after last key stroke.
