SusieQ
Whirlpool Duet washer won't run diagnostic tests
5 posts in this topic
Washed a load in my WFW9600TA00 Whirlpool Duet washer. Noticed that items on top of the machine had moved to the back of the machine when I returned to dry the load. When I started the next load the machine powered up normally, door locked, selections entered, then nothing. A few clicks are heard and the time left counts down but no water enters machine. After about six minutes error code F28 appears communication error between CCU and MCU. When pause/cancel is pushed the door unlocks and machine powers off as usual. Tried to run both automatic and manual diagnostic tests but only C:00 comes up on screen and then nothing else happens and pressing button again does not advance to next test. Skip looked for loose wires and found none but our vision is not what it used to be so it's possible we are not spotting it. His voltmeter he had for 40 years cratered so we didnt get to test that way. Left the machine unplugged for thirty minutes to reset CCU, no luck. Looking for a reset method or a way to properly test which part is bad before ordering randomly. Your wisdom is greatly needed and appreciated.
The procedure to diagnose the problem is to check all the connectors to make sure none are loose, then check continuity on all the wires between the ccu and mcu. If all that check out ok the next step is to replace the ccu. If it still doesn't work replace the MCU.
In my experience it is almost always the ccu, except in a few cases where water had leaked on to the mcu.
Shortcut- make sure mcu stays dry. If it does, replace CCU
Unfortunately there is no good way of testing these parts short of just visually examining them for burned components.
Even then, more often than not, there is no visible damage.
The fact that it does not go through the test cycles is a good indicator that the problem lies with the ccu.
There is a slight chance that you will have to replace both parts, but I'll bet dollars to donuts that it is just the ccu
Part # W10157913
Part link: http://www.repairclinic.com/PartDetail/Main-Control-Board/W10157913/1454652
It does seem to be the theme du jour with these newer generation Duets (with the steam expansion board) of bad CCU's covering a multitude of sins from failing to enter diagnostics to F35 and SUD errors.
