pelampe
GE Triton dishwasher leaking
13 posts in this topic
Hello,
We have a GE Triton dishwasher that has suddenly started leaking below the bottom on the LEFT side, in multiple areas.
Model No: GSD5940DO1SS
It begins immediately after the tub is filled up with water and the the wash cycle begins. When I say "the wash cycle begins" what I mean is that I can hear the rotating arm spinning inside the dishwasher.
What do you think is causing the leaks to occur?
I have attached photos below:
Inside View
Front View
Zoom-In of Front View
Please let me know if you have any more questions.
TIA,
Phil in Ocean Springs, MS
All leaks are visible, meaning their exact point of origin can be visibly discerned.
In your zoom-in view, can you point out the specific location of the leak source?
May require laying on the floor with a Margarita and a flashlight and watching while the dishwasher is running.
I put some cyan-colored lines below so you can see where the drips are coming from.
SEE BELOW:
If I was a guessing man it sounds as if the power shower tube is leaking. It goes from the main motor, along the left side of the tub to the top of the dishwasher where it supplies water to the top wash arm.
http://www.repairclinic.com/PartDetail/Water-Line/WD24X214/271968?replacedManufacturerPartNumber=WD24X222
So, this tube is active during the washing cycle?
I guarantee you that I'm way better at guessing then you are!
But guesses don't count.
Did you see my reply above?
The fill tube or the fill cup is leaking.  You'll need to pull the dishwasher out far enough to get a visual on that full assembly which is on the LHS, toward the back.  The problem may be apparent.  If not, you'll need to run it in that position (may be difficult depending on installation) so you can see from whence the water originateth.
Take a 6' stainless steal dw hose and run it in the middle on the floor who that you can get a better visual.
Can you please tell me where the fill tube is located on this diagram (which part #)?  Also, do you know of a parts list for this diagram?
And YES, that is exactly what I'll be trying to do next (taking a 6' SS hose and connecting it to the dishwasher after I pull it out).
1.  Pull the dishwasher out from its cubby
2.  Located the water inlet valve-- it's the one that has the water supply tubing connected to it.  Will either be copper or steel braided.
3.  Locate the rubber tube on the other end of the water fill valve and follow it all the way to the side of the tub.
It appears to be the power shower tube alright.   It is leaking a hugh amount of water right where it comes in to the top of the machine.  There is an elbow fitting going through the top of the machine, and it has a crack in it.  The water is escaping through that crack and then passing over the top of the machine then downwards on the side to the floor.
The elbow appears to be soft rubber.   If purchase this part, will it be simple to just pop it back in through the top of the machine where it came out?  It doesn't appear that there are any special tools required, to replace it, correct?
Can you think of anything else I will need to have (or know) to replace the shower tube?
Should just need the new tube, it comes with the soft rubber elbow attached to the corrugated plastic tube.  Just pushes back thru top and upper spray arm seals it again the roof of dishwasher.
Take the upper roof spray arm ref#570 off before trying to remove or replace the power shower tube.
The shower tube is basically already off of the top of the dishwasher.  See below:
Why do you suggest taking off the roof spray arm BEFORE replacing the tube?
The reason I'm asking is because the two screws holding the roof spray arm are severly corroded.
See below:
I can remove the screws using a grinder and if I do that then I suppose the roof spray arm will be able to be released from within the top of the dishwasher.  I can  then get two replacement screws to reset the roof spray arm.
If you don't remove the spray arm there is a high likely hood of not getting the lip of tube back into the tub correctly and still having a leak  when you are done.
The spray arm mounting base is what squeezes/seals the lip of the tube to the top of the dishwasher tub.  Top of tub might already be rusted and when spray arm is removed and tube installed may not have any sealing pressure on the tube lip anyway and still have a leak without using some kind of sealer around the tube were it enters the top of the tub.
The correct way to reinstall is by removing the spray arm first, removing old tube, reinstalling new tube then reinstalling spray arm.
